Parts are then vapor blasted in the Vixen AquaBlast, then immediately rinsed with clear water, dried, and sprayed with protectant.
Let me clarify that 'protectant' comment a bit - There are a few flavors of that, mine is good ol' WD-40 at the moment. That serves the dual purposes of protecting steel bearing inserts from flash rust, and restoring some of the luster to the aluminum (aka "makes it look great")
Nils Menten
Yes, but how is WD-40 a long term (more than a few days) solution? If I am doing an R80 G/S engine case and going through the trouble of dis-assembly, rebuild and re-assembly, then I want the protective finish to last.
Consider getting into clear anodizing and you will have a long term solution to corrosion. That I would be interested in.
By the way, since I am familiar with media blasting and the bright finish it leaves, a coat of WD-40 is what will take a bit of that brightness away which is what I was referring to.
One more tip from me, Nils.
Swish Facto AT34 is an aluminum brightener (also sold by WĂĽrth in a spray bottle but expensive for the small quantity) that I have used for many years.
It depends on the aluminum alloy, but in most cases it does a great job. By the way, this is a last resort for brightening aluminum (removes corrosion) and it not to be used on anodized finishes.
I used Facto AT34 on the engine case in the flywheel area of an old R65 that I used to use for my Euro tours. The R65 was 14 years old at the time and the flywheel/clutch area looked like crap. Sorry, no before photo and this after photo is as good as it gets since it is a scan of a photograph.
Of course nobody likes to let out proprietary secrets......The reading reminds me a lot of Soda Blasting.
SB is one of the new ways of cleaning material with minimal damage to the base material. I guess the next level up is walnut shells.
It would be nice to get an engine spiffed up without disassembly.
I just want to mention that I have known Nils for many years and have a lot of respect for him. He's one of the good guys.![]()
