Thanks for this! Like the OP I had read somewhere that keeping the fob within range could drain the fob battery. I therefore kept the fob in the house and when I was working and this would, about 10% of the time, result in me going back into the house after I was geared up to get the fob when the bike would not start.You can store the fob wherever you wish. When you push the ignition-on button on your bike it sends a signal and looks for a response from your fob. That is when the fob becomes active and sends a coded response to the bike. The fob is not activated simply by being near the bike with the ignition off.
Where did you find this info?You can store the fob wherever you wish. When you push the ignition-on button on your bike it sends a signal and looks for a response from your fob. That is when the fob becomes active and sends a coded response to the bike. The fob is not activated simply by being near the bike with the ignition off.
My anecdotal experience is that if the Fob is close to the bike (closer than 4 or 5 feet) the Fob battery doesn't last very long however if stored further away the Fob battery seems to last six months to a year.
The fob will start the bike without a battery. The battery is needed to give the fob a range of 2 or 3 feet from the receiver. The bike can be started if the fob is placed on the receiver."the radio-operated key..." has a battery inside. No (or dead) battery, no start.
I agree. If storing the fob near the bike would cause a problem there would be a warning in the manual.the lack of any warning in the OM about storing the FOB in range of the bike is instructive.
I keep reading conflicting information about whether leaving the fob within the range of the bike will cause the battery of the fob to prematurely weaken?
