Why no "Show All" link at the bottom?
Bud
It is what it is.
Visit 10+ forums a day.
This is the only one on which I can not use a "Show All" button to not have to page thru page after page to read an entire thread.
Am I missing the obvious? If so, point it out.
If not, why isn't there a choice to see all of the responses to a thread with one click?
Ummm cause it does not look like vBulletin supports it. I just thumbed through the PDF. However you can set it so your default is 40 posts per page.
vBulletin doesn't support it at this point. Sorry. I think we're looking at upgrading, but I'm not sure if that's a feature or not.
The upgrade could be kind of messy, given the customization we've added.
If you go to your UserCP and select Edit Options, you can select how many posts you'd like vB to display. Right now, the max is 40 posts per page, which, for this forum, will probably cover most threads.
Thanks for being so kind in your reply.
:banghead Tip of the hat to the Grand Poobah and Ben for pointing out that 40 posts would cover most threads. :clap :clap :clap
I was missing the obvious. :banghead
