A
awshucks
'81 R100T 41k, starteds smoking a bunch left side on cold start. Eliminated side stand issue and I think reed valve, disconnected air box to intake set up and let oil collect in air box for 140 miles or so. Didn't solve smoke problem. Had put about 1000 miles on new to me bike w/o problem.
Pulled heads and cylinders today, lot's of burnt oil build up on left, minor signs of same on right.
Minor delay to get spring/valve compressor tomorrow, pics then. Did find both pistons had ring gaps aligned. Left w/ in 1" for all 3, right side, nearly a straight line for all 3. Compression test shortly before all this showed about 115, same both sides.
Mechanic buddy says it's normal for rings to spin on pistons whilst running, what are the odds they both ended up the same or nearly so? Does his airplane engine knowledge apply to Beemers?
Also, had rumors of one of two PO doing some valve work due to '81-84 having exhaust seat/valve condition. Can't get any paper work, but did check valves w/ magnet, both exhaust valves non magnetic, both intake are magnetic.
Does anyone know what's up w/ that? Were they that way from BMW or does this tell a tale?
We're going to check the end gaps on rings tomorrow, will know more then. Tia for advice or comments!
