AjaxTheDog
Problem solved! Not what I or anyone else suspected...
In the interim between my last post and now I also developed a leaking rear shock. Oil dripping onto the exhaust and smoking was...well, a smoking gun! Good thing because I might not have noticed otherwise. So I brought the bike to BMW of Denver on New Years eve for both this and the hard start issue. New rear strut was installed and they first diagnosed the hard start problem as being due to a questionable throttle valve switch PN 13547696412. They said that "...throttle position sensor ...was found to have an open position in the sweep." and replaced it. That helped but did not totally solve the problem so they swapped in a fuel pump electronics PN 16147720777 from another bike and this did solve the problem. I believe that is the injection fuel pump, which is not something I would have ever guessed. So anyway it took a couple of weeks but they did diagnose and solve my problem. I thought the bike ran fine before but now it is smooth as silk and seems to have more power. I am probably dreaming that but it definitely does idle more consistently, no hunt whatsoever, just thump-thump-thump. They were also trying to talk me into a new set of plugs (they said these were dirty) but since these only have 5K miles on them I declined. I may just put in a new set for the 18K mile service. The last thing they said was that the Odyssey battery I have does not seem to have a very good cold cranking output. I suspected this as the original battery just seemed stronger on a cold crank. Oh well, I guess as long as it fires up that doesn't matter so much to me, but I think when I do need a new battery I will go back to OEM.
Lastly I have to say that I really like BMW of Denver better than the other dealer in town, Foothills BMW. I had a similar starting problem on my old 07 RT and Foothills never did fix that, they just said I had to live with it. That and a few other semi bad experiences have turned me off to their service department, so I have decided that BMW of Denver is my new preferred dealer. They are very reasonable and seem to have better diagnostic skills that go beyond just plugging into the bike computer and looking for a code. I like that and plan to write them a thank you note for this very good experience.
So anyway, case happily closed! Thanks everyone for the suggestions, I appreciate the effort and advice.
