Just finished checking the valve clearance on my GSA. Everything was within spec with the measured clearances more towards the smaller limit (tighter) rather than the larger clearance limit.
I always assumed the clearances would reduce over time as valves "wore in" but a friend recently told me that with these bikes the clearances get larger with time/use.
Is that correct?
Is that correct?
