S
sbosbach141157
I have recently purchased a lowered 1983 R80RT where the upper attachment point of the Koni shocks were moved forward two inches, front forks slid up in the triple tree 5/8 inch. The bike came fitted from the PO with a Dunlop 491 (110/90 B18 61H) rear tire in combination with a Metzeler Marathon 110/90 57H 19 front. I measured the actual widths and profiles of both tires fully inflated with no weight on them. Actual widths were 112 and 102 mm respectively. Actual profiles were 85 and 77mm respectively. Both tires have tread depth around 2-2.5 mm and are only a couple of years old. I'm running 37 PSI rear and 35 PSI front with two up.
OK, so much for background. My riding from years ago on Honda's tells me the bikes handling is not right. There is a strange disconnection from the road feeling, as if the bike was "skating" or slipping around momentarily. This seems especially noticeable by my passenger, enough so that she is leery of riding two up until I get this fixed. I also have a leaking steering damper, but there is no sign of head shake or wobble, just a vagueness about the directional line, as if the bike were not firmly planted on the pavement.
Being new to BMW, I need some experienced opinions before I go replacing tires and parts.
Steve Bosbach in Austin, TX
