I transitioned to a “gravel bike” well over a decade ago. At that time “gravel bikes” didn’t really exist, because disc brakes hadn’t made their way over to roadbikes yet in any significant way. So rim brake calipers limited the size of wheels/tires that could be used. So I purchased a cyclecross bike and modifued it somewhat to be mire if a gravel/road bike.
I am still riding that bike today and will never go back yo a straight roadbike. I find roadbikes are just too limiting. This bike can run up to 38c width tires, but I typically run 28, 30, or 32c depending on anticipated terrains. 30c ends up being a very good all-around width, and running at <60psi the rude is softer. I can ride anything from rough rutted gravel/packed dirt to pavement. I have no trouble jeeping up with pure roadbikes on pavement, either.
This really is my “anything bike.” Short of technical mountain-bike terrain, it can handle almost anything. It’s really nice to be able to plan a multi-surface jaunt, or happen upon some unexpected gravel path or shortcut/detour and not have to turn back.
The modern breed of gravel bikes are even better, purpose built with improved disc brakes and better gearing options now with the new groupsets. I can’t recommend this style of bike enough. Very versatile and fun.
Oh, man, I was out riding and this is my first opportunity to respond to powwow. I love gravel bikes!
Like vark, I had a road-ish bike that was capable of wider tires. In my case, I used 30mm cyclocross tires because I was using traditional road caliper brakes. Even with 'just' 30mm, I had to deflate the tire to get it past the brake pads. But I did enjoy riding the bike and it got me into the world of gravel riding. It also gave me the experience to chose the appropriate gravel bike for me.
So a couple of years ago I built up a gravel bike. Titanium - for all of the same reasons I gave for road bikes. My second choice would be steel and it would move into first place if I didn't have corrosion problems because of my sweating. The reason that I wouldn't choose carbon is that I tend to ride aggressively (stupidly?) in gravel races and the ones I do here in the northeast end up having some difficult terrain (like single track and extreme pitches) and I have crashed in many of those events. Titanium and steel generally shake off those types of incidents - I just don't know about carbon. If your chances of crashing are slim or you are a sponsored racer, then carbon may be a good choice. I also use my gravel bike as my EVERYTHING bike. It really does it all - from touring to racing. Mine has mounting points for racks and fenders for a touring setup. Many of the original carbon gravel frames were pretty specific to racing and didn't have those. New bikes are coming out every day, though so I'm sure there is a carbon solution fon everyone.
I have two sets of wheels for my bike. One setup for road with 28C tubeless (on C17 rims they measure 30mm wide). One setup for gravel with 40mm tubeless. I am seriously considering a 650b pair (27.5 inch) with 2.1" mountain bike tires for the really rough and muddy stuff.
There are so many things to think about and new stuff is coming out all of the time because gravel riding is becoming popular. Now there are 1x drivetrains. That isn't for me - I run 50/34 with a 32 or 34 cassette. That allows me to ride the bike as a road bike but still tour and climb pretty well. 1x is nice and simple but you have to give up something.
I have a 15mm thru axel on the front and wish that I had a 12mm. I got my fork when gravel was still borrowing a lot from mountain bikes. Now they can share parts with road disk. The 15mm is beefy but overkill for my needs.
Recommend 160mm disks front and rear. Michelle (my wife) is really light - <100lbs - and I put a 140 one the back of hers. It just makes it a pain because it is different than all of the other wheels. It works fine for her, though.
Lastly, and most important is fit. I have my bike set up fairly close to my road bike. The front end is just slightly higher. I do use mountain bike pedals. Handlebars are identical shape as my road bike. Some people like a bit of a flare on the drops for gravel. I haven't tried it.
My last comment would be that my gravel bike could really replace all of my other bikes right now. I also don't do 'hardcore' mountain biking anymore because of the potential for injury. What I do could be done on a gravel bike with MTB wheels. Gravel bike is almost as fast on the road as my road bike it just weighs 1.5lbs more (due to disks, beefy fork and frame). It is a great touring frame IF you are OK going fairly light. It is NOT a Surly Long Haul Trucker.
I don't have any good photos of my gravel bike (there is one from a distance earlier in the thread). I'll take one tomorrow and post it. I'll also take a picture of my new titanium rack that I just got a couple of months ago.
If you have any questions, I would be glad to answer. The thing that has really made the gravel bike possible is disk brake technology. Take an old school rigid mountain bike, add disk brakes and drop bars - and engineer a few lbs off. That is gravel. Pretty much just a decent all around bike.
Great stuff...thanks so much for your in depth response. It does seem that there is a lot of innovation going on right now in the gravel bike space, so lots of choices and more coming all the time. Agree it could conceivably become my one bike quiver.
One thing that I didn't mention in the previous post is that gravel bikes have a pretty relaxed geometry. The head tubes are a little longer, the seat tubes and steering tube maybe a little more slack. You appreciate that when descending down a steep gravel road. But it doesn't feel as 'quick' as a road bike. I think we all gravitate to that relaxed geometry as we age - I notice that there are a lot of 'endurance' geometry road bikes in this thread. .
I don't understand what these "gravel" bikes are you're all talking about?
How many bicycles do you folks have. Complete bikes? Bike equivalent parts piles?
I don't own a bicycle. I haven't owned one since 1959, the year I bought a moped.
But I am enjoying this thread. I get the impression that some folks have more bicycles than I have motorcycles.
So, fess up folks. This is a quiz. How many bicycles do you folks have. Complete bikes? Bike equivalent parts piles?
So for the last couple of weeks I have been trying to put on 'Henzilla' miles. 370 miles in 14 days. In the first 3 days of May we have put on 131 miles with 4700 feet of climbing - the Strava challenge I'm doing is 777 miles and 25000 ft of climbing. So I have a good start.
We are now using local villages as goal destinations and our 'trophy's are photos of our bikes at the Village welcome sign. Today the destination was Port Byron, a supply stop on the old Erie Canal. We hopped on the canal trail for about 6 miles (total ride was 45 miles). Perfectly do-able on road bikes. Finally, a warm sunny day in central NY.
