St tank for g/s
berndt
A friend has a st tank I'd like to fit on my 84 g/s but it looks like a different gas cap. Is there an adapter or way to put a screw it in gas cap in an st tank?
The ST tanks use the same flat gas cap w/flip up handle that was used on all the BMW bikes those two years. #5 in the picture below.
If the tank you are looking at has a raised lip, it’s not an ST tank.
Best,
DeVern
The early R80GS had a different filler cap than the ST. The difference is how they vent. The GS had a vent tube coming from the cap. The other airheads including the ST vent through the cap without the exposed hose. I went the other way and put a R100GS tank on my ST.
My 1986 G/S had the PD kit installed by the dealer, so I got the stock tank (plus other parts) when I bought it.
The stock tank has a screw-in cap and only one petcock. Kind of a lightweight mechanism (both cap and tank neck).
The PD tank has mechanical quarter turn cap onto a much sturdier tank neck, but vented by rubber hose to the atmosphere.
