When was the last time you had a peek under the valve cover? This thread may be relevant-
https://forums.bmwmoa.org/showthrea...-prematurely-worn-cam-lobe(s)-in-your-wethead
Let us know how you make out.
Good luck.
That does seem odd.
Could short running periods result in increased moisture in the engine? (letting the engine run for 15+min may reduce this?)
Is that corrosion at the spark plug seal? Did you wash the bike with a pressure washer?
