rangemaster
Member
I was contacted by one of MOA’s Consumer Liasons...they had this situation examined and they contacted BMW...
BMW NA indicates its’ records show my bike now has ASC, and it should be enabled all the time EXCEPT when turned off with the ASC switch, which doesn’t appear to make any difference. It is BMW’s opinion what the switch may be defective.
My thanks to the Liasons for their efforts.
Perhaps the switch or connection is bad, I’ve seen stranger things.
I ordered a new switch but will have to wait 2-3 weeks as none exist in the USA.
In my examination of the circuit diagram all the ASC switch really does is provide a temporary path to ground (31) on the ASC input of the ECU (BMSK-P) module.
What I find very odd is that while BMW says ASC is now installed and is likely just working all the time (and can’t turn it off due to a wonky switch) why doesn’t the instrument panel indicator act as the manual describes?
The ASC light (to my knowledge) should slowly flash on bike startup until it’s moving at 3-5 mph (like the ABS indicator does). This doesn’t happen. Ever.
Could someone with a Hexhead and ASC see if this is the case?
