I bought this LWB Toaster tank 900 miles ago. It had just under 15,000 miles on the odometer which did not appear unusual based on the condition of the bike. My first task was to check all of the fluids then drain and replace. At that time I noted that when I loosened the inspection port on the final drive unit, the gear oil literally gushed out. What was not lost in the gushing was measured at 400cc. The unit holds 250cc which I replaced. At that time, I also noted that I could not get a reading on the shaft drive fluid level. I drained that fluid and replaced with the measured amount of fluid as indicated in my Clymer's guide for these models.
900 miles later I endeavored to check the fluids once again. Tranny oil is fine but, as before, when the final drive unit's inspection/fill port was opened, a gush of gear oil ensued that forced me to reinsert the cover. Also, as was my prior experience I could not get a reading on gear oil in the shaft drive. As before I put on my thinking cap.
What is different now than then is that I have joined the BMWOA and have access to the collective brains/experience of its members. One working theory was that gear oil was migrating from the shaft drive into the final drive unit but I could not a seal in the parts diagrams that would be the migration path. Another theory was that the bike was sitting too far rearward on the centerstand thereby allowing the spill. This theory is pretty lame even in my mind.
Does anyone have any thoughts on the subject or approach to diagnosis.
Thanks, Schwarze
Thanks, Schwarze
