So here is what I tried. First if the rt bulb light shuts off, if I turn ign key off then on, it comes back on with no other action, then goes off again later, so a heat issue or bad connector would not be that problem as it happens whether the bike is running on the street or in the garage. I also tried different bulbs, added a resistor even though the bulb was suppose to be canbus compatible. Swapping rt to left, the problem still ends up on the rt side. if the bulb was not canbus, I should have the same issue on the left side.
If the “different” bulbs were not stock, I would try a stock bulb……perhaps both stock.
