B
bpittarelli
Greetings everyone!
I've been lurking on the board since July when I bought my bike trying to learn as much as I can. This board has really helped me and the technical information available is amazing!
The bike is a 2002 R1150RT with 45,000 miles and needed a little attention. I had all the tupperware off and replaced the front and rear shocks, adjusted the valves, replaced the clutch slave cylinder and the left cam chain tensioner.
I was in the process of replacing the cam chain tensioner when I made the mistake of removing the two bolts that hold the TPS to the throttle body. When I realized my mistake I immediately reinstalled the two bolts but I don't know if the TPS moved while they were out.
Do I need to re-set the TPS? Everything I've read regarding the TPS setting to "zero" is for the older R1100 bikes but is the procedure the same for my 2002?
Thanks in advance!
Ben
Thanks in advance!
Ben
