squeaki40wnc
Hey Fellow Oilheads, I got an oil leak coming from the base of left side cylinder where it meets the engine case on a 02 R1150RT. I'm watching some YT videos and searching around for the set of parts/tools needed to make the leak go away. Looks like I need a new cylinder head gasket, new cylinder base gasket or gasket sealer (no gasket-just sealer?), cylinder locator dowel O-rings, & not sure what else. I've got a new cam chain tensioner and crush washer ready to go when I reassemble. Specials tools include piston ring compressor & some kind of degree dial wrench gage for the primary and secondary 90 degree turns past original torque in cross pattern for cylinder crankcase stud nuts. I'll make my own gage system to mark the 90 degree turns. Looks like I need the special silicone gasket sealer (ThreeBond1207B) for the cylinder base to engine case surface. It looks like there is no preformed gasket between the cylinder base and the mating surface of the engine case--just silicone sealer? Is this correct? The Clymer manual is not very clear on this issue nor are the YT videos I've watched thus far.
Any help or advice on how-to or best places to get all the necessary parts would be appreciated. I have the cylinder head gasket from Euro MotoElectrics in hand.
Thanks, SqueakI40WNC
