T
ted1857
I have a 2000 r1100rt (26k miles). That has no slack when check at the rear wheel 6 to 12 o'clock position,but does have a small amount when check in the 3 to 9 o'clock position,plus I am getting some metal shavings on the magnetic drain plug.Would adjusting the Pivot Pin take out the slack,and should I be concerned about the metal shavings on the drain plug or is this possibly early crown gear bearing failure. Any Help would be appreciated!!!! Thanks Tommy Dixon
