Oil Temperature Display Intermitent Failure
I never thought anything would ever go wrong with my 96 R1100RT. It's pretty dependable. But......unfortunately, something has. The oil temperature part of my RID will suddenly go blank. Everything else is showing the way it should, clock, fuel level, etc. After I let the bike sit overnight or so, when I start it up, it is working again. But then I'll be riding and look down, and the bars are gone for oil temp. I have tried fiddling with the wires from behind the panel to see if it would start up again, but no luck. I have also looked in all my manuals for the location of the oil temperature sensor, and I can't find where it is either. Any suggestions on how to trouble shoot this problem, and also, could someone tell me where the oil temperature sensor is located on the engine? I assume they can be replaced if that is the problem. Anyone had this issue? Thanks for the help.
I had this problem with my '99 RT last year, about 20K miles ago. The temperature gauge would stop displaying and the bike would run rich. I fixed it by cleaning the connection to the sensor on the right side of the bike above the engine. Unplug the connector and spray some WD40 in there and put it back together. I haven't had a problem since.
Kelly
Thanks to Roger, and everyone else. I'm going to order the sensor from Beemer Boneyard and put it in. It looks like I need to take the tank off to get to it. I think I can somewhat see it from looking under the tank on the right side. I will let everyone know if that fixes the problem.
Any luck?
When unplugged or wires are broken broken, it should register overheated. If you are not seeing your bike saying it is overheated it is problaby not bad.
For example when you unplug it, the thermostat will read hot. My RT has a cooling fan, the fan goes on when the themostat is unplugged.
Also, it is easier to change the oil sensor with the engine out. I had to make my own tool to put one in after I replace my motor in April.
Any luck?
Sorry for the delay in reporting back on this job. It's actually turned into a rather long process due to me trying to accomplish two goals at the same time. While all the plastic was off, I thought I would remove the black engine guards and re-paint one that had gotten scratched. The filing went well but I have now painted it a total of four times. I'm hoping this will be the last one. Color wasn't right, too shiny, too flat, paint lifted from one layer to another, had to strip off all the paint, etc. It reminds me of how hard it is to get a good paint job on anything.
The actual replacement of the sensor was pretty easy. The gas tank mounting system is ingenious, and simple. Unfortunately I haven't ridden it to see if that fixed it. I can't seem to get through a riding season without one of these things happening.
Join the club - thankfully, mine is just annoying. Replaced the leaking vent line in the tank and filters at the same time. I must have damaged the fuel level sender in the process because it has read low ever since. The float is free of the hoses, so I guess it will give me something to do when I'm bored.
Just a final note. I got everything put back together and tested the bike. The display works well so it apparently was just the sensor that was bad. As I noted in a related thread, changing the sensor was fairly easy. Innocent as I am, I thought the tough part of the job was over. Not true. Putting all the plastic back on this time was a nightmare. It took days and the use of a Dremmel tool to get it all fitted back on. Mainly the tank cover screws lining up. But all is well, again. It, and I, am back on the road with an accurate temp display. Thanks to all who helped on this. I appreciate it.
Glad she's back together and functional. Equally glad that RS plastics are off and back on in just a few minutes.
