Help needed with getting to and tightening an Oil Sensor on a 2001 R1100R with 7500 miles. The Oil Sensor 19 mm nut was loose and causing a substantial oil leak when under pressure. I may need to replace it but wanted to try tightening it first. Just can’t get an open ended wrench or socket in the area it’s located. The manual shows it needs to be tightened to 30 NM. Prior to the oil leak the bike was stalling and running rough at startup for the 1st minute or so then it would level out and run somewhat ok. This started after installation of a Hall Sensor and AF XIED. This leak was noticed after pickup from a mechanic who couldn’t identify the cause of the idle issue after trouble shooting. Could this possibly be the cause of my idle problem (a loose or bad sensor)?
