Replaced dead battery with LiFePO4 Motorcycle battery, no start, no hazards, no turns
mkeehn
Hello everyone
I have a...rather curious issue with my 2004 BMW r1150rt. As the title says, I replaced an old AGM battery with a new "Battery Tender" (Deltran) LiFEPO4 motorcycle battery (Part # BTL14A300CW).
Previously, the bike would start up, albeit slowly due to the dying battery. Now, the bike activates ABS, flashes the brake light, and the red hazard light is lit right underneath.
I pulled codes via GS911, stating the following:
3 fault codes found:
821 Hall sensor 1, no signal - this fault will always occur if engine not running or engine not cranked before reading Fault codes.
The fault is currently present.
288 Throttle Position Sensor, Internal Fault on Upper or lower Potentiometer Slider.
901. Hall sensor 2, no signal - this fault will always occur if engine not running or engine not cranked before
I also attempted to calibrate the throttle, but kept getting the error that the idle switch was off. I am unfamiliar with exactly WHAT an idle switch on this bike is. Google searches discussed the choke cable on the left handlebar, so I loosened the cable until there was slack, to ensure the choke wasn't on. No change in error message.
But, here's the most interesting part. With the key in the "ON" position, NONE of the handlebar inputs work. Blinkers, hazards, horn, windshield adjustment, headlight beams...nothing! Previously, I could turn the key to the "ON" position and perform most of these inputs with the engine off.
I had removed ALL of the fuses (wasn't sure where #5 fuse was, from left-right, or right-left looking at the fuse cluster), and let the bike sit for an hour. I then replaced the fuses from the outside in, ensuring that either #5 fuse would be the last insertion.
Still no joy. Handlebar controls are still non-functional. Starter doesn't engage. The kill toggle switch works, turning off the transmission shift notification on the LCD and causing the ABS to go silent. I tested turning the bike on in neutral with and without the side stand extended. Pressing on the brake lever when the key is in the "ON" position does activate ABS; ABS doesn't appear to be negatively impacted by this issue.
Further, GS911 was able to give me the ECU software number and other information on the ECU. In my experience with BMW cars, if a DME (e.g. ECU) is bad, INPA/ISTA cannot read it period. I think that the motorcycle ECU should behave in a similar manner?
Anyways, I'm at a loss at this moment. I took off the left-side tupperware again, just to verify TPS cable is attached. Again, NO connections, except for air box, were disturbed during the replacement of batteries. And yes, I charged the new battery before installing.
I am eager to hear any thoughts on potential issues I should check.
Thank you everyone!
Mike
Just throwing this out there, if you put the old battery back in how does it act?
Maybe a bad battery?
No good. Just went out and did just that. Battery voltage on new battery is 14.80. Voltage on old battery is 14.35.
Anything else to try? Could I have maybe ruined something when I connected the negative terminal (I connected positive first)? There was a tiny spark across the negative terminals when I touched the cable to the terminal.
It's just very odd. All fuses check out fine also.
I have BT batteries in all of my rider bikes. Airheads, Oilheads, Harleys, KLR, old Honda's, etc.
If you are getting a hall effect code, maybe you disconnected something accidentally while installing the battery.
Could also be a coincidence, or the frayed HE wires had enough juice to finish themselves off.
No, I'm not affiliated with BT at all. Except maybe I put the owner's kid through college, lol.
Sent from my SM-G975U using Tapatalk
Can't help with your questions but just an observation and question of what you're reporting: Typically, battery standby voltage is 13.v; so why would you replace a perfectly good battery?
Generally, alternator output voltage is around 14.1v to 14.3v regardless of the battery installed unless there is a huge load on it; like electric clothing and/or heated grips.
So the standby voltage on both batteries exceeds the nominal output voltage of the alternator?
You might want to check the accuracy of your voltmeter if you're relying on it for diagnosis.
Joe
Grounds and more grounds
Check to make sure all of your negative connections, battery forward, are connected.
I usually will take every ground wire off and clean them.
The other thing you can do is take your positive post from your DVOM and connect it to the ground. Take the negative post from your DVOM and connect to negative on your battery.
Crank engine, take reading, if more than 0.5V, you have a ground issue.
That's a voltage drop test and a powerful tool.
Joe
First off, it's a Harbor Freight multimeter...maybe that's the problem, LOL.
I'll break down and buy a proper Fluke and test voltages again. Also, connections are clean, no corrosion.
But, even if the bike won't turn over...shouldn't minor systems, like the hazards, blinkers and horn work with key on, engine off? Also, the old battery has been sitting on a trickle charger - I have yet to put it on my carbon pile load tester, but I anticipate that its CCA has degraded significantly, given its near-dead performance when starting the bike.
The engine won't crank at all. Again, only change to bike was swapping batteries. Regardless, I'll try your suggestion.
The H/F dvm is "close enough" for basic troubleshooting, whether for voltage, current, or resistance.
The '04 1150 doesn't have the "disintegrating HES wires" issue.
The "tiny spark" may have been caused by current flow to the clock (a very tiny bit, though...) or to the starter, alternator, ABS controller, flasher relay, optional equipment connector (including the spare power outlets), radio connector, and the up/down switch for the windshield - these are all connected directly to the battery + by sometimes roundabout routes.
You say that previously, the bike started "slowly", attributing that to the low battery... It's also easily possibly that your starter was dying, and is now actually dead. Some starters had the magnets come loose and jam it up inside, others just catch a ton of crud in the nose gears (this is cleanable).
The TPS and the HES both plug directly into the bike's computer; it could be worthwhile to pull the gas tank and verify that that connection is clean, the pins are straight, and it's fully plugged in/seated.
Interesting opinion concerning the starter motor. I had done a complete R&R to the bike several months ago (it's a relatively new acquisition) (e.g., new clutch with longer spline, bearings, brake pads/lines, fuel filter, plugs, LED lights conversion all around, new alternator, etc.,) and one thing I did do was disassemble the starter motor's gearing assembly and applied some Honda 60 moly lube on the shaft/fork and sprocket. It was moving back and forth MUCH better after that. I also rerouted the hall-effect sensor wires so it wasn't sandwiched between the alternator and engine block. I know the horror stories of the engine heat over time melting the insulation, causing wire shorts. And yes, I did ensure there was plenty of slack in the hall-effect wires - no wires suffered any strain ;)
Also, not related to this issue, but I did disassemble my ABS unit to clean out any carbon gunk in the twin electric motors. The motor internals were actually not all that bad, even the contacts had a decent amount of material left. I took some pics of the disassembly, perhaps I'll start another thread and discuss that project.
Those HES "horror stories" relate directly to the "environmental" insulation that got used on some of the earlier years. That stuff was guaranteed to break down.
Paging GSAddict and Anton (or anybody who "knows"): Have you heard about any melting HES wires on the later oilheads?
I just went out and did a carbon pile load test on the old battery. I came out to 210 amps.
I think you might be correct on the starter motor. But again, how would a dead starter motor contribute to ancillary items like the windshield adjustment not working when the key is in the on position? I'll remove the motor and take a look at its internals. Perhaps it's something as simple as replacing the contacts? I'll also bench test the starter motor.
More to follow.
Strictly speaking, it shouldn't.
On the other hand, if a bad starter causes over-heating damage to the starter relay and it then "sticks", anything else on that circuit would also be affected (low voltage caused by not enough supply current).
Several years ago, I encountered an R1100S where a bunch of the wiring harness to the starter had melted - we never were able to decide if the starter burned the relay or the relay stuck and burned the starter.
Further testing
All,
I've continued testing with the excellent electrical schematics drawn up by Mr. Doug Raymond https://www.mac-pac.org/tech/electrical-diagrams/. Also donated $20.00 for his efforts.
Anyways, it appears, per his schematics, that the "Load Relief Relay" is the lynchpin to providing power to handlebar control items (e.g. hazards, blinkers, high/low beams, windshield adjuster). But the interesting part is that the solenoid portion of the relay is grounded directly to the starter solenoid. This gave me a clue, as manually actuating the "Starter Relay" could complete the "Load Relief Relay's" circuit, as it too, provides a ground connection upstream from the starter solenoid. I removed the plastic relay cover off the "Starter Relay" and, with the key in the "OFF" position, I manually completed the starter relay circuit.
Sure enough, lights, flashers, and even the windshield adjuster came back to life. The horn was the only thing not working, but I see on page 3 of the schematic that the "Horn Relay" would have to be actuated by the key switch in order to receive power from the "Load Relief Relay". I did not investigate that segment any further for now.
My initial reaction is that the starter solenoid is bad. I did continuity checks across the solenoid and came up with 0.3 ohms - which at first blush would generically conclude that the solenoid is working fine. I wasn't satisfied with that test, so I pulled the starter motor off and did a bench test. I was unable to actuate the solenoid plunger by applying current across the coil. So I decided to connect power directly to the motor itself; No joy. As Dr. McCoy would tell CAPT Kirk: He's dead, Jim.
I have a new starter on order. I will install and test again. However...I'm a bit suspicious of the key switch as well, since the "Horn Relay" failed to actuate when the key was in the "ON" position, even when I manually closed the "Starter Relay" switch. Looking at page 3 of Doug's schematic, the "Horn Relay" receives positive voltage from the "Load Relief Relay", just like the flashers and other ancillaries, BUT...the positive voltage comes from the key switch, and grounds out when the horn button is depressed, which should actuate the "Horn Relay" and cause the horns to sound off.
But...since I manually induced a complete circuit via the "Starter Relay", I want to hold off on throwing parts at the bike until I can definitively prove that the starter motor is not the only issue. Manually closing the "Starter Relay" obviously, does not turn on the Motronic circuitry directly, so again...I'll wait for the starter.
More to follow.
Mike
Those 1150’s had notoriously tight wiring at the key switch and sometimes it would result in broken wiring right below it.
I’d check out that wiring harness as well… Good luck!
