ANDYMCLAIN
Any ideas to stave off numb tingly hands? Good soft grips, gel gloves or maybe another model bike with different riding position? I ride an R1100S.
Classic symptoms of carpal tunnel syndrome. It's usually worse in the morning?Same problem, starts with my thumb and index fingers, and radiates to the middle and ring fingers.
If you have numbness or tingling in your hands -read this...Classic symptoms of carpal tunnel syndrome. It's usually worse in the morning?
Suffering from it - I can tell you so far what has helped me:
1. Foam grips - larger diameter to grip on, some isolation from the normal vibes
2. R1200R vs R1150RS - couldn't ride the RS anymore. Can ride the R12R.
3. Restrictive splint for nighttime use. Everyone tends to fetal position at night when sleeping (MD told me this.. it must be right, it is for me..) which folds the wrist at an angle that will cause irritation of the nerves running through the carpal tunnel. The splint keeps the wrist from being bent as far. Takes a week or so to get used to wearing these at night.
4. Some sort of throttle relief. I use an O ring between the grip and the bar-end weight. It makes the throttle basically neutral - if I set it to some position, it will hold the position for about 15 seconds and then very slowly close. This allows me to lighten my grip on the throttle. That lessens the stress on the wrist and vibes getting to my hand.
5. Good tuneup. It's possible to get an R1200R motor to make almost no bar end vibration at usable RPM ranges if it's tuned correctly. Doing it right requires attention not only to throttle-balance, but also to valve adjustment and rocker arm end-play (which can make a BIG difference.)
6. Steroids. Specifically - a cortisone prescription if you're planning a several week long ride. There are risks and possible side-effects involved in this - make sure you discuss that with your MD before he gives you the prescription.
7. Gel palm gloves. Seem to help a bit. There are some specifically made for this problem (I saw them at the MOA rally) - but I haven't tried those. I've just used the Olympia gel-palm gloves. Also in the winter - heated grips helps as do thicker gloves.
That all said - I'm probably a candidate for surgery for it - but I've been stalling it until it's winter and I won't miss riding the bike for a month or so. There is surgery done now that only involves a very small incision in the wrist and one in the palm of the hand. That's what I'll be looking at.
Interesting - what/where do you find the liners? I have some silk ones that I haven't worn in years.. might be worth trying them. Also interested in your results from the special gloves.I bought the gloves @ the TN rally and will see how they do once I can take a long ride. I wear a thin poly liner with all leather gloves and find from many miles that it is the one best thing you can do on a bike other than a throttle assist, short of the surgery, when the time is nigh!
It does lessen your resistance to infections - I proved that with a toothache during the MOA rally. Stopped taking the steroids and the toothache went away. The local dentist I found thought it was the steroid and the heat - lowered resistance to infections.As to steroids, I took them for years until I lost 30% of kidney function from contracting a virus while backpacking. I have plenty of osteo arthritis in my hands besides the CT issue and it helped to "loosen up" my hands. I miss it dearly and there is no substitute.
I know EXACTLY what you mean.. first time I really had problems was after an all day session with a hand held leaf-blower that had a small 2 cycle engine. The vibration is the real culprit there.I suspect that string trimmers were invented by a sadistic hand surgeon.
I'm seeing the guy who invented the endoscopic tool that is used by most surgeons now. He came recommended by quite a few friends who had success with him.My warning: Be very choosy which hand doctor you choose to see!!! I found that it is common for them to do the wrong tests or not do the right tests and the list goes on. Read as much as you can find online before you ever leave your house.
One word........Goldwing.
I have an appointment for the electro-tests with a neurologist. The cutter MD insists on this before applying the knife. I've been told these tests are similar to techniques used on.. well, we won't go there, but lets say Dick Cheney may have heard of the tests
Interesting - what/where do you find the liners? I have some silk ones that I haven't worn in years.. might be worth trying them. Also interested in your results from the special gloves.It does lessen your resistance to infections - I proved that with a toothache during the MOA rally. Stopped taking the steroids and the toothache went away. The local dentist I found thought it was the steroid and the heat - lowered resistance to infections.I know EXACTLY what you mean.. first time I really had problems was after an all day session with a hand held leaf-blower that had a small 2 cycle engine. The vibration is the real culprit there.I'm seeing the guy who invented the endoscopic tool that is used by most surgeons now. He came recommended by quite a few friends who had success with him.
This getting old stuff is really hard isn't it?
It's an interesting test. First they strap you to this board...............
