There are holes in the motor case that I do not understand. These are about an inch behind and a inch above top rear of cylinder base. (hole is about 6mm dia.) Why are these holes on both sides on a /6 (R60 and R90) but only on left side on R100s (/7 and PD)??
Are the tops of the cases under the starter cover exactly the same on the /6 and /7? Possibly the area is shaped differently and will only really drain to one side. I know that on the /7, the breather valve and associated plumbing for that is on the right side under the starter cover. IIRC, it's located somewhat differently on the /6.
