In both cases I think you should. No Kool-Aid involved.
If you can't stand having BMW on the part, get the equivalent from Mahle ... but be sure to get the Made in Germany Mahles and not the made who-knows-where relabeled Purolators.
Kind of wondering,other than the price,what is special about the BMW filters and oil ?
My guess, the filters are well made and have several markups. The oil is formulated for BMW with generous additives for motorcycles by Spectrol and also has several markups.
But is it BETTER than everything else?
Sorry, I simply can't help but ask the question the begs asking.....
Can anyone give me a good reason that they would buy ANY aftermarket oil filter for motorcycles that cost what BMWs cost?
Seriously, I hear about guys trying all kinds of CHEAP oil filters on these machines, when a new one from BMW runs $15 and change.
I don't throw money out the window and I ride more than the average rider does. I change oil on the average of 4-5 times a year. Under $80 a year to protect my engine the way BMW thinks it should be protected.
What am I missing?
Exactly what I think every time I read one of these sorts of posts. Given that you can order any part online these days and have it delivered in no time, I don't quite get the convenience rationale either, but each to his own. If I had a bike that was still under warranty, I'd be using a BMW oil filter (in fact, I'm well out of warranty, but still use a BMW filter). Not so with oil, since BMW doesn't make oil, or any sort of lubricant.
They don't make filters either, but what they specify including oil and sell is probably a good choice...and an easy choice. If not the BMW oil, I would probably use Castrol, Spectro, or maybe that Amsoil motorcycle specified oil.
Chris, exactly why is it that you need to get the "German" Mahles?
Ken
...put it to bed for the winter.
do you use the same oil the next year? what if you only put another 1500 miles on it that year?
can you use the oil till you get to 6kmi if it takes 3 seasons?
FWIW, simple storage (without frequent starts of a motor that never really comes to operating temp) doesn't have to be any kind of concern and water accumulation in oil or a fuel tank is easily kept to an insignificant value simply by preventing a lot of air exchange through the the crankcase or gas tank.
The same way that a full fuel tank won't accumulate water and rust its headspace (in the old days of real metal fuel tanks), the intake and major vents of a motor can be covered or plugged, limiting water vapor condensation by preventing or slowing the intro of new damp air that holds more water. Though I would also point out a fact well known to folks living in freezing climates- namely that cold air contains little water to condense anyway.
Combustion of course creates both water vapor and carbon dioxide from fuel being consumed and that water can become a significant issue if not removed eventually. The water can also become part of combustion related acids which will not get removed by heat- they need to be neutralized by the oil (see the base number spec for your lube).
The amount of water created by combustion is very large compared to what little is in air that might get into the crankcase and condense- folks in cold climates know about water tha drips out of cold tailpipes and the clouds of water vapor that occur when motors are started in the cold and have cold tail pipes- that eventually get hot enough that the combustion created water vapor stays invisible. All motors allow combustion gases into oil through leakage past rings, crankcase air vent/recirc systems, etc.
