Dash differences between hexheads and camheads?
DavidR8
Active member
Hi folks, I've been asked if I'd make a version of my GPS mount for the 2005-2009 RT
Problem is I don't have an RT of that year and can't find one locally.
Does anyone know if the top profile of a hexhead dash is the same as a camhead?
Barring that, I need to see some pics of the top and riders view of a hexhead RT so I can compare it to my camhead to see if my design will work.
Thanks, they are definitely different as the 2005-2009 mounts from Wunderlich don't fit a 2010-2013.
The simplicity of your mount may still allow it to fit both models. The Wunderlich grips the back edge of the dash differently between models but your mount doesn't do this. The instrument cover or surround is different between hex and cam heads but the upper trim panel is the same part for both and that part sets the distance between the bolts that secure your mount to the fairing bracket underneath the trim panel.
I'll try and get some pictures of my hex head dash for you.
Brilliant, really appreciate that Dave.
If the trim piece is the same then the curve of the top must also be the same?
Here's some pictures of my 2007. The top of the upper trim panel has to be the same because the BMW part # is the same. It is peaked slightly. I installed a B-309-1U clutch reservoir ball on top of the dash with one of the screws and a strip of double sided foam tape. I carry an iPhone on that one. The other two Ram balls on the base of the handlebars are Ram B-367BU mounts for the GPS and a Spot Tracker.
Thanks for those pics Dave.
The dash top looks completely different from my 2013.
From Max BMW I get the following part numbers.
P/N for 2010 -2013 is 46 63 7 711 707
P/N for 2005 - 2009 is 46 63 7 681 279
In any event I think I can work from those pics.
Thanks again!
Thanks again!
Double check the parts diagrams. Both models use part 46 63 7 682 929, upper trim panel. This piece has two holes in it which bolts pass through to attach the panel to the underlying frame bracket. Your mount uses those same threaded fittings through the trim panel into the threaded part of the underlying frame bracket. That distance between holes is the same for both models. The radius of the back edge of the trim panel appears to be the same for both models though the 10-13s extend the cover aft to form more shade over the instruments below.
The two models utilize different instrument covers, yes, mentioned above in #4, but they both fit against the same part - upper trim panel - which determines the radius of the different instrument covers (dash top) so they both fit closely against the top rear edge of the upper trim panel.
If you are willing and want to, make a cardboard template of the aluminum plate and I'll see how it fits on my bike or if you prefer I can make one and send it to you to see how it corresponds to yours.
Sent you a PM Dave
