M97 Gearbox Disposal
m_stock10506
Well-known member
I just replaced my 1100RT gearbox with a low mileage replacement in apparently good condition. My old gearbox is high mileage, with worn input shaft splines. The box shifted very well, and did not shed any metal particles on the magnetic drain plug. The replacement was due to a stripped clutch hub, not the input splines.
Aside from pulling off the fill and drain plugs, are there any other parts that I should consider saving?
Or, if someone wants a gearbox to take apart for internal parts, or to rebuild, I would send it off to you for the cost of shipping. Otherwise, I’ll remove whatever I can and dump the rest.
Michael
Please let us know how this works out so it can be deleted when you are done.
We don’t want someone a couple of years from now trying to contact you. 😊
The Moderator Team.
Michael - I would be interested in this transmission as a learning exercise. My R1100RS transmission is still original and still good. I have re-built several airhead transmissions, but haven't taken apart an oilhead one. I can ride down to your place and pick it up when ever you like. You can call me or send an email to let me know your wishes. [Note to others, Michael and I live about 30 miles apart in NC].
Members helping Members. :thumb
I will leave this up for a day or so as a great example for others.
