rabbitgtibbar
Had the recall performed yesterday, and even as I was getting onto the bike the brake lever seemed too soft (I squeeze it as I get on). It went nearly all the way to the grip. I went back inside and asked the service manager, who had the tech come out who explained that was because I had the knob “turned all the way to 1”.
“Well yes, that’s where I like it. And the lever engages much further than it did before when it was set to 1.”
“Well, I bled it.* I had to turn it to 4, but I put it back to 1 because that's where you had it.”
So, I’ve set it to 4, but I still feel like it engages lower than before.
I guess what I’m asking is, did anyone else feel like the brake lever engages lower after having the recall performed? Is it possible the new calipers have a larger volume, and since the master cylinder is the same, it now requires more lever travel to engage the brakes? Or do I have to ride an hour+ again and go back to the dealer to have them bled/looked at again? Or, having done it many times before on cars, is this (bleeding the front brakes) something I could tackle at home, if you all think that might be the issue?
/I tried to search the forums and see if this topic has come up before, but couldn’t get any results. Sorry if it has.
