Loading Routes into a Zumo 550
tmwilmotte
Member
I recently loaded four trip routes into my Zumo 550, but I had to do it one route at a time. I couldn't get the Zumo to accept four routes sent to the device individually without "managing" each route one at a time by disconnecting the Zumo from my computer before loading another route. (My Old Garmin 2720 was much easier and faster.) Am I missing something here, or is there an easier/faster way to load multiple routes? :dunno
First, how are you creating the routes? If Mapsource, just create a route, then use Edit | New Route and you can add however many you need. Then just upload as usual.
Keep in mind you transfer Folders to your Zumo, not routes. What's inside the folder gets loaded.
It's kind of like iTunes creating playlists: You have your everything folder or "My Collection" and then individual folders.
You can make a folder with a name like "Summer 2012 Trip" or 'Sunday rides" for example. From there you create your trip routes or Waypoints while the folder is selected. Everything will always be in your "My collection" folder. To create a new folder select from file menu "New List" and name the folder whatever you like.
That's why it will ask you you check off whether you want Routes and or Waypoints transferred at the time you select "Transfer to device". You shouldn't have to check off "Maps" being transferred, just Waypoints and Routes.
Let us know if that works. You can also drag things from one folder to the other at least using a Mac with Basecamp.
