pappy35
Member
Finally got around to installing LED turn signal bulbs. I sourced these from a vendor in China and, as advertised, they are plug and play, no resistor needed, no hyper-flashing, and no CANBUS errors. They are very bright and seem to work in the reflector housing just as well as the OEM incandescent bulbs did.
Note: check your bulb mounts before ordering. On my 2013 RT the fronts and rears are not 180 degrees apart, they are offset (whatever that's called I don't recall). The rear mounts are metal and the bulbs went right in despite this. The fronts though are plastic and they didn't just pop in like the rears did. I found it was possible to insert them in the front plugs and they will twist and lock in place and work (I channeled my inner gorilla-mechanic and used a pair of pliers) but I did have a moment of panic. If you buy these, buyer beware. They may make one that has the correct offset tabs and this link is NOT to one of those.
Rear OEM vs. LED
Rear Both Installed
Front Both Installed
No CANBUS Errors
Rear OEM vs. LED
Rear Both Installed
No CANBUS Errors
