I changed the final drive oil about a month ago with 80/90 GL5 gear oil. Last week I noticed gear oil on the rear wheel. It looked like it was leaking from the drain plug, so I got some new washers and replaced them. That did not stop the leak and after careful assessment it appears the oil is coming from the back of the final drive, between the drive and the rear rotor. Looking at the Max parts fiche it appears that it may be the gear housing o ring [33 11 1 241 257] that may be the issue. There doesn't seem to be any play in the rear wheel and besides some very fine black crud on the magnet, the oil looked clean with no metal shavings ;so I think the gears and bearings are ok. I am an intermediate mechanic but have not had to deal with a final drive . I'm hoping that whatever seal or o ring that may be causing the leaking is not too difficult to access and replace. Advice. ? The bike has about 70K mi. , I've only owned it about a year and have no idea if the drive has ever been apart.my manual is no help as it advises to leave the final drive to professionals.
Advice. ?
Advice. ?
