Semper_Fi
Honey Badger
As you wait for the rear drive fluid to drain out, take the opportunity to clean out the drain plug.
The drain plug has a magnetic insert which gathers all the metalic materials in the fluid.
Shown below is the inside of the drain bolt after cleaning out - took about 5 minutes with some brake-clean and quetips.
SHOP TIP - Before inserting the drain plug - you may want to check the o-ring to ensure it is not damaged or shows wear.
If you have done the fluid drain 3x with the same o-ring gasket - you may want to replace it.
After the draining is complete - reinsert the drain plug and torque to 20Nm
