KGT Air Cleaner Replacement
Semper_Fi
Honey Badger
The articles, posts and comments in this tech section are posted by individual members and reflect their personal thoughts and experiences with repairing, maintaining, and generally working on motorcycles. This information may require specific knowledge and skills, may or may not be correct or current to model.
The authors of information found here and the BMW MOA take no responsibility for ensuring the accuracy of any information (including procedures, techniques, parts numbers, torque values, tool usage, etc.), or further for any damage of any kind or injuries incurred or caused by anyone following the instructions or information found here.
It is the duty of the individual to either assume the liability himself for responsibly using the information found here, or to take the bike or accessory to a Dealer or other qualified professional service.
Lastly, please ensure you dispose of your used chemicals, oils and fuels in an environmentally responsible manner. Most Auto Parts stores and service stations will accept used oil and lubricants, tires and batteries, please check for your local availability.
This article, text and photos are Copyright of the individual authors and the BMW MOA, any copying or redistributing is permitted only by prior written authorization.
TOOLS:
T-25
PROCESS OVERVIEW
  • Remove Throttle Side Panel
  • Unbolt bike computer
  • Pull out locking pins on air box
  • Remove snorkle assembly with air filter
  • Remove and replace air filter
  • Insert air filter into snorkle
  • Install Snorkle and filter onto bike
  • Install bike computer
  • Install Throttle Side Panel
Take side panel off - to do so you need to remove the following T-25 bolts
3 in the glove compartment
1 on the inside by the tank
3 along the bottom of the panel
4 along the inside egde of the panel
Shown below are the three for the glove compartment
This is the bolt by the tank - it is also the longest one at 50mm
These are the lower three panel screws.
Please note that #1 is 16mm; #2 is 20mm;#3 is 16mm
There are 4 inside screws
Should below is the top one - which is 16 mm
The final bottom one is 20 mm
In all the 4 screws (in order (top to bottom) are 16, 20, 20, 20mm
With all the bolts removed you can now remove the panel.
Note that there is a pin on the outer panel that mates onto the side
With the panel off, we need to access the air snorkle, this is done by first removing the computer mounted on the side
The bolts are identified with the green arrows, the one in at the 9 o'clock position is behind a wire harness
With the bolts removed you can pull off the computer from the rubber mount on the left
Pull the computer off and let rest off to the side
Now you have complete access to the air snorkle which when removed allows you full access to the air filter.
To remove the snorkle you need to unclip (in 2 places) the air box section and then pull off the snorkle from its pinned attachment
Shown below is detailed the bottom clip unlocked but not removed
Clip detail - here is the clip removed.
The green arrow is pointing to where you should press to unlock the pin to remove
With the airbox clips removed - grab snorkle as shown with right hand, grab airbox area with left and pull straight out towards you.
There will be some slight resistance as the snorkle section has a pin and grommet fit and the airbox guides are a tongue and groove set up.
Shown is the detail of the pin and grommet connection
