bmwgsrider
Member
I am glad you were able to solve your problem and found dead center. When you say 1 shim off... you meaning to loose or tight?
Turns out the intake valves were within spec ( towards lower end of normal range ), but the exhaust valves were both way too tight. I couldn't even get a guage under one side. I actually had to get shims that were .30 mm thinner, if I recall. That's more than two sizes thinner. In fact, there is only one shim thinner ( 2.30 mm ). Anyway, it brought both exhaust valves within spec. The bike is back together and running fine.
