BBrowning
Active member
We use to do this quite often in the Automotive world. Put the head light in series with the battery cable and the Battery post. When you had a harness short or some such and needed to have a good resistance to take some of the load while you looked for the issue. Pulling each circuit fuse until the light went out would identify the short or draw. Then a methodical harness wiggle or device disconnect on that particular circuit. Could take time but sometimes the smoke would let you now exactly whereIn addition to the above, and I mentioned reacquainting myself to a multimeter in a range I don't normally use, this Wagner Halogen Headlamp (or something like it) can be a good was to check and test to be sure you are in the right range-
H4656, Wagner Sealed Rectangular Halogen Beam (Low) (18533)
Low Beam Halogen, 18533, low beam halogen, low beam, halogen, federal, wagner, H4656, Wagner Sealed Rectangular Halogen Beam (Low) (18533), LITE, Lights, Lamps, Bulbs, Head Lamps, H4656 Halogen Headlight Bulb, H4656 HALOGEN SEALED BEAM, 01-AH-4656, H4656BULB, 15-34656, 02144913, 08312707...www.unityparts.com
- Design Volts Secondary: 12.80
- Design Watts Secondary: 35.00
- Design Amps Secondary: 2.73
