topophilia
Seeking the collective wisdom of this group.
Back-round; 2016 R1200RTW with 42000 miles. recent battery which tests good. Problem exists with a different battery as well.
Problem; Phantom electric draw when off. All tests as follows are repeatable and documented.
1) All peripherals are disconnected so that the bike is in the "as delivered" condition.
2) Start bike with ammeter connected between the battery negative post and negative cable.
3) Turn off bike and amp draw runs approximately 3.3 amps and as low as 2.6 amps.
4) After about 60 seconds, a relay behind the diagnostic port clicks, the exhaust flapper releases and amp draw drops to around .57 amps.
5) After about two minutes, amp draw decreases to .1 amps and remains there.
6) I have systematically disconnected every connection plug I can find while watching amp draw but have not found the phantom draw.
At this rate, the battery is depleted at the rate of about 2.4 Amp Hours per day and is insufficient to start in about a week.
All tests have been run many many times and repeat with the same results. All of these tests have ALSO BEEN RUN on an identical bike equipped exactly the same and manufactured just 33 serial numbers apart.
The results are nearly identical except that the control bikes resting amp draw drops to 0.0 amps after about two minutes.
Any ideas? I appreciate any thoughts.
Bob
Bob
