Heated Vest or Heated Jacket Liner
I've got plenty of sae cabling. I'm just wondering if I can use that [ or perhaps need an adapter ] that's already directly connected to the battery that plugs into the warm and safe.
If that's the case, I just need to run a splitter on the sae at battery and run one cable to the side of the bike where the liner would plug into.
Another option for you if you don't want a controller and have a CANsmart with an open port (I'm assuming ezcan as well since one seems to be a rebranded version of another).
Wire it up to that and set it to turn on with your heated grips. You can customize what % of heat with each level the grips are on.
