The headlight used in the classic Ks is the best light BMW ever put on a motorcycle. You may need to clean it internally, or it needs adjustment.
I would try getting your existing headlight up to snuff (including as a previous poster said, making sure your reflector is clean and also instide of the lense. If the outside of the lense is especially pitted or cloudy, you might try finding one in better shape.
Think about the relay.
Get a higher performance bulb in place. Even going to a new stock wattage bulb can help, "they" say that the bulbs performance does diminish with useage and time. Avoid a bulb with a tinted glass, like these blue colored bulbs.
I would disagree that there would be a problem with Xenon. BUT I also know there is much debate about it. Might see if you can locate an owner with this particular headlight style and see what their experience has been.
Additional lighting IS available in hid/Xenon.
Gilly
Correct - and a bi-xenon will never have the arc discharge in the same place and as important - the same shape as a dual filament bulb.Actually on a H4 bulb conversion, you would need to go to a bixenon to have high and low beams. Also a shield to block glare.
No, my tongue was not in my cheek when I responded. I've put something over 400,000 miles, many of them at night, on a K100RS and K1, which use the same headlight. The only thing that comes close is the /6-/7 headlight.
If you look into a replacement bulb, you will run into Sylvania and Osram H4 units.
There is a difference between Sylvania and Osram Silverstars. The Sylvania seem bluer, and tire me out more on long night rides. After switching to Osram Silverstar, there seems to be less glare and I see better. I think the blue tint of the Sylvania Silverstars gives an illusion of clarity that is not borne out in reality. My unscientific cateye reflector counting indicates they are of equal brightness, with perhaps a slight edge to the Osram. When riding in wooded areas, keeping an eye out for deer who are not looking at me, I give the edge to the Osram, as it seems that there is a little more depth to what I see beside the road. With the Sylvania, everything seems flat, like a set in a stage production or something like that. If the deer is looking at me, both seem to pick up the eyes equally well, although this is just observation, as it is difficult to be objective with different deer and conditions each time. As far as looking straight down a paved road, the difference is not as noticeable.
Keep in mind that my elderly, lens-assisted eyes might be different than yours. One riding friend who has had Lasik really hates the Sylvania, and loves the Osram. His preference for the Osram is much stronger than mine. Says MUCH less glare.
Nope. Used the Osram H4 bulbs in K75's for years..I appreciate your info on the osram and sylvania, at first I thought they would be the same because Sylvania owns Osram but through some diligent digging I do see there is a difference in Osram and Sylvania Silverstar bulbs, they also say there is a slight difference in the base for the H4 to be used on motorcycles, Sylvania says to order a H4ST from what I understand it is just the way it fits into the plug. Did you run into that with the Osram.
www.powerbulbs.com - in the UK, but they ship for free to the US - the shipping is fast (less than a week) - they have currency conversion right on their website and they usually toss in a freebee of some sort. Good people - I've been using them for years and have been very satisfied. Oh - besides the Osram Silverstars - the Philips VisionPlus +50% bulbs are also good.Also where did you purchase the osram and how much. I believe that is what I am going to go with for right now.
