2,500? I would still be in first, even if I was flower sniffing. I like to keep the RPM over 3,500.
Same. Different engine, but I don’t like to lug around. I’m even thinking of changing the drive sprocket ratio to get higher revs around town.
Ever turned on the shift-up indicator? You'd be amazed... Most of the time I'm just in town, not going fast. This thing pulls hard from idle, and there is no need to keep the revs up. It's just so smooth shifting at 2k.
I don't own motorcycle with a shift up indicator. My 1984 Pontiac Fiero had one. It was a joke.
Again, toodling, not "turning the power on"...IMO, 2,500 RPM is to low for turning the power on.
Finally found the guy that bought the Fiero
I'll tell that story. Voni decided she wanted a Fiero. I did some research and told her that would be a bad idea. One of her students found a nice (Red of course) 1984 Fiero for her to look at. I showed her my "research". The then current Consumer Reports book Guide to Used Cars had, out of all the makes and models listed, just one - exactly just one - Do Not Buy recommendation. The Pontiac Fiero. So she bought it anyway because she liked it and wanted to. Within a month or two I bought a Ford Bronco II, a highly recommended model. So in the few years we owned these two vehicles I had several issues and breakdowns with my Bronco II: brake lines, water pump, alternator etc. Her Fiero was flawless with only one repair beyond routine stuff like oil changes. I had to replace a battery cable. I am reminded of this experience every time I look at vehicle ratings.
And an RT is heavier than an R.
Edit: It's almost like all you people run WOT every time you start from a stop or something...
