awagnon
Member
I purchased a 2006 F650GS with a little over 7,000 miles on the odometer. I rode it home about 700 miles from where I purchased it. After sitting over night in my garage, I noticed it was dripping oil from the engine. I had a hard time finding the source, but I believe it was coming from the air box. It had enough oil in it that it was coming out the air box drain tube and around the tube. I estimate a couple of ounces of oil was in the box. The oil level was above the level of the drain tube. I know on my RT, if you over-fill it, you get oil blow back into the air box. I checked the oil level in the tank, and it was too full. Is this the same on the F650, or do I have a problem?
