Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
My 2001 f650gs overheated due to a radiator leak,
and now there’s coolant in the oil. Any thoughts or ideas
on how to fix this? Head gasket? Cracked head?
Most of the time a pump-up test of the radiator is in order. Barring having the real kit, pump sorta looks like a sports ball pump, I have drilled a hole in a (spare) radiator cap any used low pressure to check and listen (gurgling) for the air leakage and where it’s coming from.
All that said, chances are it’s a head gasket especially if the bike had been run hot at one time. Most repairs are going to require some disassembly. Some changes in coolant (anti-freeze) actually helped degrade the head gasket over time.
Let us know how you make out.
Good luck.
