beemerguru
Member
Got a call for a rider in the middle of nowhere...literally. His steering head bearings are badly notched..no shop for a couple hundred miles. Usual response is
'call a dealer and have a new set shipped in.
But then we started talking about what people in REALLY out of the way places like Africa or the bush country in Australia would do..or have to do.
When head bearings get notched, is the notch specific to ONE set of opposite points on the races? And if so could one knock out the races, rotate them 90 degrees and reinstall? Clean, grease the bearings and have no notch? Or would the bearing also suffer from the notch...and if so, could you also rotate them.
I know the right answer is always replace...but this question kept bugging me so I want to ask the group and see if someone with the expertise can answer the question....can head bearings be rotated and reused for a medium/long term fix is necessary?
