MOTOR31
If you are going to stop, then by all means pull in the clutch. As far as swerving or other evasive maneuvers are concerned, you maintain power through the swerve to keep traction, momentum and positive control of the vehicle. Pulling in the clutch means you have to then rematch the revs to the speed before adding power to move through the obstacle, that induces a new control parameter when you need it the least.
Why endanger your rear wheel traction by having to re engage the power system when you had it all there to begin with? The turn itself is going to scrub off speed and you need to have some speed to complete the move then continue on your way. Or in the case of a Motor Officer, come back and write the ticket to the person who created the situation.
