Just a tip:
The most difficult (frustrating, time consuming, PITA) part of changing the clutch cable on any early K (K1, K75, K100, K1100) is feeding the lower accordion boot through the too small hole in the tranny. There is NO reason for that hole to be that small. So everytime I have someones tranny out for a spline lube or tranny repair I enlarge the hole. It only takes a few minutes (less time than it takes to feed the boot through).
First take a 9/16" (Silver and Deming)drill and enlarge the hole. Then follow with a 5/8" drill. Since it is not a complete hole (interupted cut) you need to be carefull that it doesn't bite in. Use high speed with a VERY light feed and drill more vertical than the angled hole actually is to keep from biting in.
It makes removing and installing the cable a breeze from then on! Remember, don't touch the rear most hole where the cable actually seats! This MUST remain the standard size.
