cookie
Jeff
I have changed/flushed the brake fluid on my 08 RT at least 2 times without any issues using Mr. Semper Fi's, awesome step by step instructions.
I was looking through my Haynes manual specific to this motorcycle and there is a warning:
"Any attempt to drain and refill the ABS in the conventional way will result in air trapped in the system and brake system failure-On machines fitted with ABS it is not possible to change the fluid without the use of a diagnostic tester-the procedure must be undertaken by a BMW dealer."
Considering I have had no issues with the brake system on my RT and the brakes perform better than my highest expectations, I can only assume the editors of this Haynes manual are either mistaken or stupid.
What are your thoughts?
