bohdi36
I recently purchased a 2004 r1100s Boxer Cup Replika, ( 19,000 miles) the charcoal canister and catalytic converter was removed. The hoses for the canister were tucked up under the rear side panel and not capped. My question is there a procedure on properly removing the charcoal canister, or should I try to reinstall it? I would prefer not to install the converter, I don't have the original converter, but I do have the charcoal canister with most of the parts.
I will tell you, I was having problems with low idle, so I capped off the two lower vacuum ports on both throttle bodies and readjusted idle and throttle body synchronization, the bike performs a ton better.
