hotwheels22
hi all,
new owner here with one more question. i just finished sorting a r100gs and actually at the last step had to take it to a mechanic to get the timing set and to balance the carbs.*
i am wondering if anyone would mind walking me through a carb balance with the spark plug extenders from northwoods. i bought these (i don't have a harmonizer) with the idea that if i am in the middle of nowhere i will have a good way to balance the carbs.
anyway, i have done a ton of reading on this and it is time to take a stab at trying this. to /some/ extent i almost think i could ride the bike and tune the carbs by iteratively continuing to turn the mix screw in on the side of the bike that the mirrors are wobbling. anyway, i tried it by ear and i am close but i would like to try the spark plug extenders.
it does seem like there are three different methods for doing this and having the opportunity to discuss it with someone would be super helpful.
thanks in advance.
- jon
*actually i think i was able to get the timing set but i was not able to get the carbs to get the bike to idle. for some reason one side had to be turned out much farther than the other to get them close to balanced and things were sounding somewhat clunky. then i got a big backfire and since i had just done the top end i thought i better bring it in.
anyway, i /think/ that basically i was trying to get the carbs to sound balanced in the garage (which they did not) and that next time i will open the mix screws all the way up to two full turns out and take it out on the road and /then/ balancing the carbs by turning the mix screws in as the engine heats up. not sure if that makes sense but it would also be great to get a little info on how to get the carbs up and running just after you have set the timing, adjusted the throttle and enrichener cables, and set the idle set screw...
thanks in advance.
- jon
