D
DanMoyer
I have an '06 K1200R. One of the H7 headlamp bulbs burned out. While changing it, the little wire spring-clip that holds the bulb in place, was dropped and lost down a drain hole. Looked up the headlight parts fiche & noticed that the clips are not shown. Contacted two dealers who confirmed that the clip isn't on the fiche and doesn't have a part number. Both said that the only way to get a replacement clip was to buy the complete headlight assembly!!
I contacted BMW Motorrad Customer Service in both Canada and the U.S., and was told that there was nothing they could do about it and that all I could do was to "register a complaint", which would then "go into their system". They said that I would receive no feedback from them and that if the dealer says that I have to buy a $500 headlight assembly to replace a 3-cent clip, then that was what I'd have to do, and there was nothing they could do about it.
Is this what BMW calls "Customer Service"?? Obviously somebody made a simple mistake when creating the fiche and the parts list, but BMW won't take any responsibility for it and won't do anything to correct it. Their answer is to make you, the customer, pay hundreds of dollars for an assembly you don't need, just so you can get a replacement for a 3-cent wire spring clip.
If you get a chance to meet any BMW company reps, bring this up and ask them to justify it.
