On my bike the low beam had gone out. Just getting by with high beam for a short while. It also went out.
I took the headlight apart figuring that the old LED system went bad. I have a new one for it. Plugged in the new one, only high beam. Plugged old one back in, only high beam.
Brought out the multi meter. Set on high, Yellow to brown 12.10 volts. Y to white 12.10 volts. B to W 0 volts. On low beam the measurements are Y to B .01 V. Y to W .01. B to W .00.
Looking in the Clymer manual for BMW edition M502-3, on pages 784 to785, it shows Brown as being the ground wire. From the readings I took, it looks like Yellow is acting as ground.
The schematic also shows the yellow wire from the headlight connecting to “Crt board contacts”. Is this between the speedo/tack? As I tried to figure out what it was, the best I could do is the drawing on page 430 of the same book.
If that is the problem, would a Catdash system be a good choice for replacement.
Any and all information is appreciated. If I need to dig into it to far, I will just put it back together and run on high for now. It’s not as bright as new car low beams. I want to be able to go on one more lunch run with my son when he can fit it in.
