K Bike relay box layout
RANBUSH
Ran Bush
I was going to post this in the DIY Forum, but it didn't let me; Lee, should this be moved??
I found this info and JPG from a 1999 post by Paul G. on the IBMWR Forum.
https://ibmwr.org/index.php/1999/03/01/relay-box-layout/
I have 9 components in the box – two are (optional).
Starting left to right across the front:
1. Small Black – Fuel Pump Relay
2. Blue Bosch 30A – (Optional) Low Beam Driving Light Relay
3. Blue Bosch 30A – Headlight/Load Shed Relay
4. Blue Bosch 30A – Horn Relay
Center Row left to right
5. Black Rectangular – Bulb Monitoring Unit
6. Blue Bosch 30A – (Optional) High Beam Driving Light
7. White Rectangular – Temperature Control Monitor – Fan Relay
Back Row left and right
8. Large Green Rectangular – Turn Signal/Flasher Unit
9. Black Rectangular with bolt on wires – Starter Relay
Note that 2, 3, 4, and 6 are identical 4 pin Bosch 30A relays. When I
added the optional factory driving light kit I could have reversed the
sockets for 2 and 6. The sockets came as part of the kit and just
plugged into an existing plug.
Assuming they bolted the relay sockets in the same as on mine, your
K100 should be the same. It looks possible to reverse the sockets for
the Headlight and Horn in the right front corner but that’s about all
that could be different. For what it's worth Clymer showed the black
fuel pump relay up in the right front corner – mine isn’t there! "
Thanks, Paul!
