k1200crazy
Any one recently tried or are using a Lithium battery for their K1200? Pros / Cons? I need to replace my battery now and am torn between the two. I have been using a BIKEMASTER Gell battery ... Thoughts?
Most LiFePo4 battery have a built in charge controller to make the vehicle's charging system works properly with the battery. Based on my research for my Nissan Leaf it's superior to AGM battery.No personal experience with this, but from other threads:
Will the charging system of the K1200 keep it properly up to snuff? And if not, would your external lithium-compatible charger pose a hazard to the bike's other electronics?
Does it have to be "warmed up" a little bit (by turning on the lights) before starting?
No direct experience with "lithium" bike batteries, but I've been using Odyssey AGM batteries for over 15 years, and the one currently in my K1200RS is 11 years old and going strong. In truth, not all lasted that long, but across 5 bikes I'm averaging about 9 years. They hold a charge for a very long time, and when they do finely wear out you see the warning signs well in advance. I'm not sure what can be improved here but the saving of a few pounds, which on most BMW bikes isn't even noticeable, but it's your bike, so do what you want.
Sadly you can't get an Odyssey for the wet-head GS/A . I wish I could, as that was the best battery I used in my oil-head GSA form 100K miles...
Sadly you can't get an Odyssey for the wet-head GS/A . I wish I could, as that was the best battery I used in my oil-head GSA for 100K miles...
Ahem, yes you can. As of last October Odyssey introduced this:
I have one in my 2020 GSA. Perfect fit.
I've used several Shorai batteries in my bikes over the years. They seemingly last forever, especially when compared to lead-acid AGM batteries. The light weight is just a bonus. Never had any problem keeping them charged using the bikes electrical system. Having said that, if your bike has any parasitic draw, like an alarm system, a Lithium battery can be pulled down faster than a comparable AGM. The only other downside is cost (but if they last 3-4 times as long as an AGM, they pay for themselves) and they don't tolerate colder temperatures as well as a lead-acid battery.
Not the same Lithium battery in the Boeing 787(Lithium Ion) vs LiFePo4. Lithium Ion is the stuff used in cell phones etc...that are known to ignite. Not the same as LiFePo4. Which is what this thread is about.Certainly a lithium battery will cause your motorbike to spontaneously combust like a Boeing 787 Dreamliner. Right?
Or simply explode in a magnificent fireball when pressing the starter button in freezing temperatures. Right?
Could you expand a little on "seemingly last forever"? Like how many years have they lasted for you? Thanks.
I put a Shorai battery in a 2001 ZX-12 I had when lithium batteries first came out. It was still in the bike when I sold it a year ago, so I'd say it lasted what...12 years and still going? I also have one in an old Ducati ST4 that must be 6 or 7 years old now, still works, although that bike has a small parasitic draw that requires I keep the battery on a trickle charger. All my sport bikes had Shorai batterys in them...zero problems as long as it was above freezing out. I'm old enough now that I no longer ride sport bikes like I used to and they have all been sold except the Ducati. I would hesitate to put a lithium battery in a touring bike where you might wake up in a hotel in the mountains with frost on the ground. There's a "warming" ritual Shorai wants you to go through before starting in cold temperatures, but I've come VERY close to a no-start condition in unexpected below freezing temps on a couple of rides.
