Battery Life
No computer required, tho' you'll need to reset the calendar and clock (menu settings)
I understand that newer bikes, maybe 2016 and up, have the OBDII diagnostic port. I have an OBDII cable that I attach to an old Odyssey PC680 and then to my car to maintain power and presets when I change the car battery. Any risk in doing the same thing when changing the battery in a bike?
Thanks Greg. No obvious progressive issues. There is an on-board voltmeter, which I look at on occasion. Never needed a jump start. The recent failure was over the winter idle, with no issues before the bike's last use. I'm not sure when the battery went bad. It maintained a surface charge of over 14. When I tried to start it recently, the initial load brought it to 12.4, then dwindled to 9.6. Removed from the bike, it reads about 12.4.
If replacement 2.0 has a short life (warranty goes through November 2020), I'll go non-OEM replacementšŸ˜Š
Thanks again.
Well, on September 13, while preparing for my first extended trip in this Covid-affected riding season, I determined that replacement 2.0 failed. Five months and four hundred miles on the bike since installation, but I don't know the actual date of failure. Max BMW ran diagnostics, determining that there was no electric system issue that would have caused the failure, including the auxiliary lighting and Fuzeblock. Cause of death - bad battery! So under warranty replacement 3.0 is being installed. That's four "factory-bad" batteries in a row, in less than two years; seems actuarially implausible!
HELP!
Thanks in advance.
HELP!
Thanks in advance.
That sucks. The warranty replacement part is good, but at this point I would be thinking about where I might be on the bike when #4 kicks the bucket. If your charging system is working correctly that points a lot of fingers to bad batteries.
Thanks for the empathy. My gut tells me the issue is more than bad randomness to experience four bad batteries. I suspect there would be other riders with this experience, and there would be a lot of noise on this forum and elsewhere in the community. Or that dealers would be aware of an issue.
Another dying battery?
First off, I'm thankful I found this thread.
I have a 2016 RT with 30,000 miles, I bought it as a demo, therefore has the original battery.
The bike lives on a Battery Tender Junior when not being used, but I do ride year round (used to be daily until about March of this year).
A couple of days ago, after about 10-15 miles, I stopped for gas, and after filling up, I pushed the starter.
Nothing but silence (not even a complaining starter). Pushed again, engine started.
This no-start-then-start happened three times during the day. One instance required three attempts dead, dead again, then start.
Next afternoon (bike left overnight without the Tender), I pulled the battery out, no sign of damage or corrosion
The only accessories attached to the battery are a pigtail (for Tender) and Clearwater Darlas
Sprayed some contact cleaner under the starter button (actually WD40 because it's all I had)
Tested the battery with a multimeter off the bike, it read 12.9v.
I tightened all connectors down and added dielectric grease for good measure.
Reassembled, and bike started first time, readout on dash went from 12.9v to 14.1v
This afternoon, after sitting on Tender overnight, bike started first time.
I had the Darlas on, Nav V in the cradle and bluetooth radio to helmet speakers.
Readout on dash went from 12.9v at start to 14.1v when idling
I rode around my neighborhood for about half an hour and the readout on the dash fluctuated from 13.8v to 14.0v.
Got home, as a test, the bike started twice without problems.
I hope it's not a regulator or starter problem, and the numbers seem OK on this four year old battery.
I'm just about to pull the trigger on a new battery, but would appreciate sage advice as well. Thanks.
The first thing I thought of when I started reading your post was "poor battery connection." From the experiences I've had I think you did exactly the right things; test then clean and tighten the connections and test again. Sounds like success to me. I think the thing to do now is keep up w/ the trickle charger and be prepared just in case of more problems, but ride on. As your success level increases your trust will as well. Good luck!
Why not consider a switch failure?
It sounds as if your charging system is working as expected. No worries.
I too think you did the right thing by securing the battery connections. You should still have the battery load tested.
Mine failed after 3 full seasons. It didn't survive the next winter storage even though it was on a battery tender. It would show 12.8 vdc on my voltmeter and drop to 8 vdc after trying to start.
Iā€™ve been wondering for some time now if anyone has ever had to jump start a 1200RTW? Even when the battery is partially slid out of that tight space, it looks like a pretty awkward undertaking.
On three different BMW motorcycles I have use 2 gauge wire to extend from the positive battery terminal to a point under the seat. With a screw-on wire nut to cover the stripped end this provides a convenient location to attach the positive jumper cable. A location for the negative jumper cable is easy to find.
Belt and suspenders folks can add a wrap of electrical tape to keep the wire nut from somehow working loose.
Don't you have an exposed remote "Positive" somewhere near the exposed "negative" terminal of the battery?
Been remiss in closing out my issue. Turns out my trickle charger was the issue - overcharging and frying the battery. New charger and new battery. No issues with the bike. Whew!!!
I've just replaced the OEM battry on my '16RT, so I reckon five years must about what you'll get
Same here, with a 16RT. A new ā€œBoxflyer approvedā€ battery will be here by Tuesday (as long as OnTrac isnā€™t the delivery service).
