99R1100RT starting electrical gremlins
khfranck
Member
I’d appreciate your help troubleshooting.
Bike has ~80k miles with the last ~10k mine.
Battery (approx 2 years old) kept getting weak but it would strong up on the battery tender. I’d hear the squeaks of the alternator belt on starting. So early this past week I changed the alternator belt. Didn’t help so I replaced the battery, too. (Yay Beemer Boneyard)
Ran great for the rest of the week local to build trust. Then took it a couple hours away on Thursday for a little trip. Super! Good stops and starts. But then this AM weak battery no start. Dash lights strong and the fan for the LED headlight string. I was far from my battery tender so I bump started it and got home. Tried to start after all that alternator charging and the starter motor engages but no crank.
Voltage on the battery when sitting is 12.3. When the starter is attempted voltage drops to 6 V.
Reckon bad starter wiring / connectors or starter itself?
Thanks for your collective wisdom.
I should say previous owner reportedly changed Hall sensor. And I believe it since it was well maintained and it’s only a start problem.
Sounds like it’s time for a battery. Voltage dropping below around 9.2 volts while cranking is a no-start condition.
You can verify this by jumping the bike as you would a car. The Battery Tender won’t do it and it isn’t good and may ruin the BT.
I suspect starter drag - either because the nose bushing is worn or because a magnet has come loose. Does attempting to start the bike cause an ABS fault?
With a fully charged battery what is the voltage key off?
What is the voltage key on?
What is the voltage with the starter cranking or otherwise with the start button depressed?
Voltage key on 12.3. Starter engaged 6 something. New battery this week.
You almost certainly have a defective starter. If it was a bad connection it would not pull the voltage down that far. I suspect a loose magnet.
Great video. Tested it like the video and the starter failed. New one on order!!
Great!
That "squeak" during starting may not have been the alternator belt - it's also a sign that the inside of the starter's nose is dry and/or dirty.
